  • 9 Vote(s) - 3.78 Average
gearchange linkage
Hi Was in France last week and when moving off after an overnight stop found it difficult to change gear. Breakdown service called for and the problem was a link rod end rubber bush had come adrift from its housing. A new one was fitted, total cost 97 euros. My Berlingo which Ive had since new is a 2007 model with 29k on the clock. Just wondered if anyone has had the same problem and or is this a common fault.
Mines quite loose, have the new one in the glovebox. The short one is only 14 euro from the main dealer
[-] The following 1 user says Thank You to corkgsxr for this post:
  • brownboots
The long linkrod on my 2006 Berlingo came adrift back around 2009. Got some araldite and glued the bush back into the housing on the end of the rod. I bought a new rod and kept it in the van for about 2 years before I had to replace the original. Cost was around £15 from a dealer. Very easy to replace when the time comes. Wouldn't pay a garage to fit it, only takes a couple of minutes to Diy.
Dave.
(15-05-2012, 06:06 PM)tanto Wrote:  The long linkrod on my 2006 Berlingo came adrift back around 2009. Got some araldite and glued the bush back into the housing on the end of the rod. I bought a new rod and kept it in the van for about 2 years before I had to replace the original. Cost was around £15 from a dealer. Very easy to replace when the time comes. Wouldn't pay a garage to fit it, only takes a couple of minutes to Diy.
Dave.
Thanks for that . I have the old one so will do that and keep it handy for when it goes again.
[-] The following 1 user says Thank You to brownboots for this post:
  • tanto
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
