  • 13 Vote(s) - 3 Average
CENTRE CONSOLE BULB
Thumbs Up
The lighting behind the heater control and fan speed control is dud.Whats the best way to remove panel to replace bulb ? I took the tray / shelf out from above the control but cannot see how to access bulb.Thanks in advance.
[-] The following 1 user says Thank You to taxi for this post:
  • jericlin
Hi taxi,
I literally did this same job 2 days ago.
At the bottom of the heater control panel there is a thin strip of plastic. Prise this off carefully and you will see 2 torx screws.
Undo these. Take out the tray above and push in the heater control panel.
You will need to manouvere the panel to access the 2 bulbs at the rear. its a bit tight.
Twist the 2 brown bulb holders 45degrees to remove.
I got replacement bulbs at halfords (about £3 for 2).
Hope this helps
Cheers
[-] The following 1 user says Thank You to sanaar for this post:
  • taxi
(18-05-2012, 08:49 AM)sanaar Wrote:  Hi taxi,
Hope this helps
Cheers
thanx for that.
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
