  • 9 Vote(s) - 1.67 Average
droplink change
Hi all, my 04 has a rattle noise from the drivers side droplink. This looks like a really simple replacement bt never done one before....anything I shold be aware of before I start?
Cheers Karl.
Jack up both sides. Also a good idea to do both sides at the same time as one usually follows the other.
If you only jack the side that needs changing it's a pig to do as the roll bar is under pressure from the wheel on the floor.
I also gave the bolts of the new ones a good dose of wd40 to help protect them rusting for easy future replacement.
[-] The following 3 users say Thank You to tucker for this post:
  • Andre, karlv, ron
also one other thing to remember when replacing is!!! the nuts have a tendancy to turn along with the shaft so use a suitable TQ socket and driver to hold the shaft whilst you unwind the nut.
I find that the torx/allen hole often round off. A mechanic friend of mine showed me a short cut. You will often find one nut will undo and the other will spin round. Undo the one and pull the droplink out from that mounting. Now, with a bit of brute force the ball and socket joint at the other end will pop apart just by levering the droplink around past the point of no return. Once you've popped it apart you can then get a molewrench onto the ball to stop it spinning and undo the nut easily.
Malc
Stupid computer!
(18-05-2012, 08:06 PM)tucker Wrote:  Jack up both sides. Also a good idea to do both sides at the same time as one usually follows the other.
Wd40 is not for that and prob not very effective, a tin of copper grease is about 5 euro, if your going to do it do it properly
engine light
Today 01:00 PM
M59 1.4 Petrol question
Yesterday 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
