  • 4 Vote(s) - 3.75 Average
how do you adjust the time?
i cant do it, there is only 2 buttons on the instrument panel but no matter how i try i do it!
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
(19-05-2012, 03:20 PM)john Wrote:  i cant do it, there is only 2 buttons on the instrument panel but no matter how i try i do it!
I dont know if the Mk1 is the same as the Mk2 but I think you press and hold the left button for a short while, it then moves through the options i.e. hours, mins. you then use the right button to set it to what you want.
Hello John
Had the same problem myself and found the answer here:
http://uk.answers.yahoo.com/question/ind...948AArE2z2
Hope it helps
David
[-] The following 2 users say Thank You to GoodasGold for this post:
  • john, zyboman
sorted, thanks to GoodasGold
Mine is an hour out through the winter and fine all summer :whistle:
(19-05-2012, 08:40 PM)john Wrote:  sorted, thanks to GoodasGold
(19-05-2012, 06:43 PM)GoodasGold Wrote:  Hello John
Hope it helps
David
Thankyou GoodasGold Worked Smile
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
