  • 25 Vote(s) - 3.56 Average
tow hitch points
hi im going to make up a tow hitch for my 07 berlingo 1.6
looked at the net picts of the tow bar and it looks like
[Image: a1-bar12562944504ae188325ea7c.jpg]
looked under the van but where are the 3 holes either side?
cant see any holes at all
Drill those holes.
so is there no standard mounting points from factory?
where in the 2" rails that run down either side of the spare wheel?
Hi and welcome to the forum corkgsxr. If you are going to stick around (and please do) then when you've got a couple of minutes, put a post in the "intro" or "owners" areas to say hello and introduce yourself (and your Berlingo). Cheers
Welcome corkgsxr to Berlingo forum.
May I draw your attention to this information copied from the Departmant For Transport website and I quote,
"4. What are the requirements to fit a type approved tow bar?
If you wish to tow anything with a car which was first used on or after the 1st August 1998 the car must be fitted with a type approved tow bar.
5. My car was first registered on 1st September 1998; do I need a Type approved tow bar?
Yes, all cars first registered on or after 1st August 1998 must be fitted with a type approved tow bar if they are to be used for towing.
6. How can I tell if a tow bar is type approved?
Each type approved tow bar will have a label, plate, or stamping detailing its type approval number for example E11xxxxxxx, and the details of the vehicle for which it is an approved fitment.
7. May I fit a type approved tow bar myself?
Yes provided you use the car manufacturer's approved mounting points, and follow the tow bar manufacturer's instructions."
So clearly, the home manufacture of towbars is no longer permitted, I have recently had a Witter towbar fitted to my vehicle, this is type-approved and all holes matched up with ready drilled ones in the chassis.
I am not in any way doubting your ability to fabricate and weld materials but just pointing out that laws have changed and in the event of an accident then not only do you risk the attention of the police but also you would undoubtedly invalidate your insurance.
http://www.dft.gov.uk/pgr/roads/vehicles...uently4577
To make you further aware, towbars now form part of the current annual M.O.T. test for vehicles in the United Kingdom
fair point but i just dont have the dosh to be buying one
made the last one for my transit never had a bother.
all im wondering is where the manufacturer holes for mounting the bar to are?
im going to fab one up i have all the stuff i need just cant find the holes. Dodgy
im in ireland so its a diff test, and i know no tester over here will fail my bars.
even after the new legislation that was to fail all aftermarket exhausts came in any i done still passed as the were welded properly and no stupid loud one at funny angles
I have done the same myself and in the past have made, modified and welded towbars but I can no longer get my materials at the right price (Does help to have worked in engineering, nudge nudge) and I am debarred from doing any type of electric welding due to having an implanted cardiac defibrillator which is sensitive to powerful electric currents.
Good luck
its the defib of be the most worryed about with welding, best be carefull with that
i have everything needed here the only thing i need is the socket but ill get that when alls made, im a plumber but iv been welding since i was 15
and im fairly good a wiring too
Hi Corkgsxr. Welcome to forum.
See in attach how original tow bar and tow ball should be mount.
I think this will help you.
.pdf   672.pdf (Size: 879.09 KB / Downloads: 61)
[-] The following 1 user says Thank You to pk7478 for this post:
  • corkgsxr
thanks the picts helped greatly
i saw those holes in the chassis do you have to drill them out?
ill take picts after i weld one up
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
