  • 20 Vote(s) - 2.75 Average
Lifting Up and Off Road Use
Hi All,
this is my first post here so please bear with me :wave:
I have a 2007 Mk2 Berlingo Multispace and consider few modifications. First of all I'd like to lift it up a bit, not just for the looks mind you, but because I often need to get off a beaten track a little bit. I have considered fitting up bigger wheels and taking off a front grille, which is the biggest problem off road, but I guess lifting it up few inches would work better. How can I go about it? Are there any kits available specifically for Berlingos? Any other off road users out there or any suggestions of other mods? Any advice would be appreciated Cool
[-] The following 1 user says Thank You to Van Worden for this post:
  • BerlingoHDI
If you could trace down one of these the parts would probably fit
There was a van version too
http://www.carmag.co.za/article/peugeot-...2004-07-01
The Partner "Escapade" has increased ground clearance
(26-05-2012, 07:28 PM)Coco Wrote:  The Partner "Escapade" has increased ground clearance
As of course has the XTR Berlingo.
In other words I would need to change suspension bits responsible for a ground clearance from one to the other? I was hoping that maybe there is a lift up kit for a small van which someone used for Berlingo but can't find any info on the net. In the short term changing the wheels might help a bit but off road tyres might not get enough clearance in the arches..
You could adjust the rear beam the raise the back end up! As for the front, Escapade or it could be worth asking about to see if the shocks/springs off a bigger model (Expert maybe?) could fit, not clue if it would though!
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
We're talking about a Mk.2 here and AFAIK the only suitable conversions are
made by a French company called Dangel and they're making a full 4x4 kit.
Mucho dinero!!
Sorry I missed the Mk2 bit Confusedillyme:
get a set of Gravel rally tyres or Mud and snow ones, protect the sump and power steering pipes as they are very exposed.
That will get you as far as a landrover or other 4x4 on road tyres will get!
There's a van version with a LSD which would be awesome for off road, dunno if it is available for mk2 or mk3
Yet another ABS fault
Last Post: leftfootleashed
Today 09:09 AM
Today 06:29 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
