  • 14 Vote(s) - 2.86 Average
Rear Wiper issues/ Fuse identification
I have been having fun with replacement wiper motors. First one I received was siezed and the second one I received has a different socket on it, presumably for a later car? Mine is a 2001 model.
However, I have been checking the existing wires to the wiper unit and I can only find one that provides 12v from the relay when the switch on the stalk is switched on. The other two wires go to earth using my continuity tester.
My understanding is that the 12v from the switch is the starting circuit, there should be a 12v feed for parking the wiper and another wire (probably the grey one) should go to earth. If one of the yellow wires is also reading as being connected to earth, it must be broken somewhere?
Would I be right in thinking that one of the two yellow wires isn't functioning correctly? I tried to trace the fuse, but the diagram I have in the haynes manual doesn't really seem to match the fuse box I have fitted in the car. Is there any access to the correct wiring diagram for my vehicle?
All help would be appreciated.
Andy
(29-05-2012, 04:28 PM)thowman Wrote:  I have been having fun with replacement wiper motors. First one I received was siezed and the second one I received has a different socket on it, presumably for a later car? Mine is a 2001 model.
Andy
Hi, if you PM me your vin No. I'll dig out the correct diagram for you. Confusedalut:
Ok, here you are. As long as your wiper has only three wires on it this should be yours.
Item 5215 is the wiper motor.
Item 5100 is the wash pump.
Pin 1 is the yellow wire which could be the park signal back to the Bsi.
Pin 3 is the Grey wire which is from the relay in the Bsi.
Pin 4 is the yellow/green which is chassis earth.
Let us know how you get on. :thumbsup:
[Image: 2v13djb.png]
Andy
I have a later wiper motor with a different connector. Will this work with this set up, or is it different? The wiring in the haynes manual seems different for the later cars.
With out knowing what this has come from I would not like to say but I'm swinging to the No side.Confusedalut:
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
