Hi all,
I installed a new Delphi 1920AT Lucas high pressure fuel pump on my Berlingo 1.9D from 2005.
Installation went OK.
Now I have a problem with the power supply on the solenoid.
(weird because bearings where the reason to change the pump)
From one pin of the plug that comes from the car I have a changing voltage from 10 to 12,5 V
The plug has 3 pins. Only one pin gives 12V normally, but steady, not like I have now.
When I connect a cable directly from battery to the solenoid you hear the solenoid clicking and the car starts. But when I connect a cable from the pin with changing voltage to the solenoid the car doesn't start.
When I follow the cables from the plug, they go to a another plug with 4 wires that is going into a sort of box, connected to the frame in front of the car on the right side)
I don't know what to do now. Ant tips?
Thanks for reading and I hope someone responds!
