Threads: 5
Thanks Received: 4 in 4 posts
Thanks Given: 2
Hi All
I just uploaded my Berlingo Firmware with 44.0705.22 NAC-r1 update from the "Citroen Update" program,
Now the maps are all yellow, of a night it lights the inside of the car up
I cant find any settings to turn the yellow off, all the rest of display is normal colour so the display is ok
any ideas
Steve
Citroen Berlingo M 1.2 Puretech XTR Flair Auto, EAT8, Cumulus Grey
with:
Drivers Assistant pack (Hmm was Not Installed but we did pay for it
Keyless Entry
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
This is with the headlights on?
Now a 2019 K9 1.2 petrol.
Threads: 7
Thanks Received: 22 in 22 posts
Thanks Given: 5
One of the menu options on the touch screen allows you to alter the settings re night screen/day screen - can't remember which offhand
2020 1.5 Blue HDi 130 Berlingo XTR
2009 1.5 Diesel Peugeot Partner
2007 1.5 Diesel Berlingo Desire
2003 Petrol Berlingo
Threads: 19
Thanks Given: 12
16
22-08-2024, 07:38 AM
(This post was last modified: 22-08-2024, 07:45 AM by Mark604.)
The handbook say -
"Modifying system settings
Press Settings to display the main page.
Press the "OPTIONS" button to access the
secondary page.
Select "Screen configuration".
Select "Animation".
Activate or deactivate:Automatic
scrolling
Select "Brightness".
Move the slider to adjust the brightness of
the screen and/or the instrument panel.
Press Settings to display the main page."
Or -
"Touch screen lighting
dimmer
► In the Settings menu, select "Brightness".
Or select "OPTIONS", "Screen configuration"
then "Brightness".
► Adjust the brightness by pressing the arrows
or moving the slider.
The brightness can be set differently for
day mode and night mode."
Also -
"Colour schemes
Depending on equipment/Depending on version.
As a safety measure, the procedure for
changing the colour scheme is only
possible when the vehicle is stationary.
Select "Color schemes".
Select a colour scheme in the list then
press "OK" to confirm.
Whenever the colour scheme is
changed, the system restarts, temporarily
displaying a black screen."
I think if you use the physical plus and minus buttons between the instruments where the trip meter reset is, when you dim the instrument lights, the screen dims as well.
I doubt if any of that helps mind you.
Threads: 20
Thanks Given: 7
15
My last update gave me ULEZ zones - these are all highlighted as yellow
