  • 7 Vote(s) - 4 Average
Oil Pressure Warning
My wife has a 1.6 petrol Multispace on an 07 plate with just under 28000 on the clock.
She drove to work this morning as normal with no problems, but when she went out to the car at lunchtime and started it up she got the flashing 'STOP' light, oil pressure light and intermittent beep. She shut it off, and called the AA as I was too far away to be of any assistance.
The patrol man checked the car, and my wife had stuck a litre of 5w 30 in earlier as the level was at the lower end of the dipstick. He started the car, listened to it, revved it and expressed the opinion that the oil pressure light/switch may be faulty. He said there were no worrying knocking/scraping/screeching noises that pointed to a serious engine fault.
She managed to drive it home under its own steam with no warning lights, and only got them back again when she parked up. Having looked at it myself, I can confirm the engine sounds normal and the oil light, STOP and beep disappear at just under 2000 RPM.
In terms of maintainance, the car was serviced last year at its MOT and has done around 7000 miles since. The dipstick was not dry before we topped up, so it has never run at a dangerous low level. It sounds ok, as I say, with no 'suspicious' noises.
I would appreciate any input which might agree or otherwise with the possibility of a faulty warning indicator, and any other possibities and remedies. We will obviously get it looked at but thought we would post on here initially to make sure we don't end up being at the wrong end of an unnecessarily expensive garage diagnosis!
I would also be grateful if someone could tell me where the plug-in point is for an OBD II scanner. I don't see one in the fuse box under the bonnet.
Many thanks
Paul
You could do with somebody connecting a manual oil pressure gauge into the main oil gallery to confirm oil pressures, but it does sound like a dodgy switch in all fairness..
Diagnostic socket is behind the removable panel below and slightly to the right of the steering wheel on RH Drive vehicles....
[-] The following 2 users say Thank You to andy-womble for this post:
  • paulandliz, ron
Change the switch,they're not expensive.It's one symptom removed.
  • paulandliz
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
