Threads: 12
Thanks Received: 3 in 2 posts
Thanks Given: 23
So my 2008 B9 has developed a weird sensation with the brakes when you first start and drive. When you are driving and press the brake pedals, you get a rough sensation through the brake pedal and it feels like the brakes are completely knackered. After driving for a few minutes, the ABS light pings on, and the brakes feel completely normal again. The vehicle passed the MOT recently, so the brakes cannot be dangerous. I need to get it fixed though as the wife refuses to get in it now.
Any ideas what is potentially happening here?
2008 B9 1.6 HDI 90 BHP Model. 120k
Thanks Received: 66 in 61 posts
Thanks Given: 2
10
First off, assume nothing with an MOT and have a look for yourself for any excess wear or corrosion.
Itf that comes up OK, I'd suggest a senssor or tone ring problem. The rough feeling being the ABS triggering.
Check the rings are where they should be and intact, clean, not excessively rusty.
Remove each sensor and clean the mounting surface. A hammer and chisel might be needed to break out the corrosion.
Threads: 12
Thanks Given: 23
I did have a stuck piston on one side and I replaced it, along with the calliper carriers. When you say sensor, I assume you mean ABS sensor, but can you post a link to 'tone ring' as I have no idea what that is.
Threads: 67
Thanks Given: 238
50
The ring is a “ toothed ring “ mounted onto the wheel hub that the sensor uses to detect motion by counting the “ teeth “. No picture sorry
That said, some cars have the ring built into the wheel bearing and cannot be seen.
Brakes may pass the MOT but can still cause issues. My old Berlingo had a max pulsing pedal and wheel lock ups when slowing on a bend - all down to worn pads discs coupled with a slightly sticky calliper.
Have fun and work through one bit at a time and then test and repeat as needed.
Serieal Berlingo owner
Threads: 67
Thanks Given: 238
50
^^^ Mad not max !! Poxy auto text !
Thanks Given: 2
10
I've jogged my own memory - on the front, they tone ring is integral to the wheel bearing, making the rust-in-sensor-housing more likley.
Rears, dunno, not taken them off yet.
The following 1 user says Thank You to shtu for this post:1 user says Thank You to shtu for this post
• flanagaj
Threads: 12
Thanks Given: 23
Thanks all.
