I've read all the threads!
I've found the three holes on the wheel at rear, and used both flathead driver and a flat-topped hax key end to try and dislodge whatever holds the airbag in... to no avail.
what mechanism am I trying to dislodge and with what movement?
Interestingly, I earthed the column temporarily and then the horn worked, and it worked when I removed the temporary earth (screwdriver end). So is it possible that when a circuit is re-used after a period, it can 'blow through' the extra resistance which caused it to cease working?
I don't use my horn a lot...! I'll monitor the situation but getting inside the wheel might help, to see if those contacts are bad. Wiggling everything doesnt feel a professional fix.
Try you tube
Iirc?- there are spring rods across the holes that your tool has to move aside
The extra earth trick seems to have found your problem
I've had it on my current b9 and earthing didn't find the issue
It was a slightly furry fuse that caused itself to blow.
Don't discount corroded terminals on the horn itself
All these little things add up.
THanks - I'll persevere. And to add to all that, my brake lights arent working suddenly. MOT approaching... I'm starting to wonder about a later model....
You don't need to remove the steering wheel. I loosely wrapped some bare wire round the steering shaft lower down towards the foot pedals and then loosened a screw/nut in the area to fasten the wire too. It's been like that for a few years now without issue.
Are the brake lights permanently 'on'? If so it's the switch on the brake pedal - it fails to 'on'. Dead easy and cheap to replace.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4  208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Fuel filler cap replacement
Today 08:41 AM
Car tax rate query
Today 08:09 AM
Tow Bar compatability
Last Post: k5d2003
Today 07:35 AM
M59 1.6 HDI lumpy idle & blue smoke
Yesterday 09:59 PM
Free parts
Last Post: OMG
Yesterday 08:53 AM
Longevity of vehicle.
Last Post: Kyleonsite
02-10-2024 10:44 PM
Engine non start obd and diagnostics required
02-10-2024 05:07 PM
Rubber Boot Mat
02-10-2024 03:11 PM
Rubber Boot Mat
02-10-2024 02:43 PM
2007 M59 Berlingo Blower fan Glove box removal
Last Post: Taffy747
02-10-2024 02:40 PM
