Trickle charge through the cig lighter socket
Hi All,
Hope everyone is doing ok.
I have a Berlingo multi space 2014 model, I have got a solar trickle charger to keep the battery topped up as it’s not my daily driver and it’s a couple of weeks maybe longer before I use it.
My question is: can I use the cig lighter socket / 12 volt socket to plug the panel into as it comes with an adapter or will I have to plug it on the battery.
If I have to plug directly to the battery Citroen in there infinite wisdom have fitted an assembly on top of the battery itself so I can only get the the positive terminal, can I fit the negative clip to a grounding on the engine bay, if that’s wrong and you fall over laughing I do apologise ??
John
Citroen Berlingo multispace 2014
Previous - Citroen Berlingo Van 2008
There is a grounding (earth ) point on the inner wing to the right of the battery. Use that
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
My K9 Berlingo turns off the cig lighter after a few minutes so I doubt it works the other way.
I installed permanent quick connectors on the battery terminals of all my vehicles so I can plug in the CTEK charger any time I need to top off or just to maintain.
ex: 2003 1.4i cargo
Thanks for the replies, much appreciated I’ll sort it when I get home
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
