Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 11
Hello there , hope someone can help, please?
Need to change front pads and discs, I have a whole range of tools, but noticed not the muiti point bits, what do I need , and what sizes?
Regards
Sent from my SM-S918B using Tapatalk
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
25-09-2024, 08:03 AM
(This post was last modified: 25-09-2024, 08:04 AM by brodfather11.)
Get a set of torx sockets, try to get a well known brand as the cheaper sets tend to snap.
Half decent from about £25- upwards.
There are female and male torx sockets/bits , a set with both will never see you stuck. The brakes need a male socket/bit for the disc and callipers.
Don't think there's much call for the female bits but you never know. The old ford escorts needed a female bit for the door hinge pins
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 67
Thanks Given: 237
50
^^ Clean the heads out first !!
Serieal Berlingo owner
• LM42
Threads: 4
Thanks Received: 12 in 12 posts
4
Just in case you’re not aware.
As far as I’m aware the Brake Caliper Bolts are stretch bolts (Torque to Yield).
They should always be replaced rather than reused.
There’s a special sequence when tightening them.
Tighten to specified torque and then tighten by an additional specified angle.
2016 Berlingo Multispace XTR BlueHDI 100 BHP
2010 Berlingo Multispace XTR HDI 90 BHP
The following 1 user says Thank You to DavidM for this post:1 user says Thank You to DavidM for this post
• LM42
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 166
21
27-09-2024, 04:24 PM
(This post was last modified: 27-09-2024, 04:28 PM by evdama.)
As Brod says get a set with both types but make sure they're impact rated and they will see you right for the future.
You would need female for the engine mount when doing a Cambelt change for example
Don't be tempted with the coated disks - waste of money....?
• LM42
Threads: 5
Thanks Given: 11
Thank you all!!! We have ugga duggas * from light weight to assault ones lol,, breaker bars , long spanners, short spanners, a hydraulic press, R tech gas welder and plasma cutter, loads of 10mm sockets.. but "specialist" bits for the above job! Thank you
Threads: 5
Thanks Given: 11
Thank you all! All done and dusted ! We had all the tools needed!
