Threads: 46
Thanks Received: 155 in 125 posts
Thanks Given: 34
23
Has your 2011 1.6Hdi M59 got an Eolys system fitted as I think they were fitted as standard after 2010? If that is playing up it could be injecting too much fluid into the fuel and causing the blue smoke/lumpy idle at start up?
_______________
Not a Citroen
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Threads: 8
Thanks Given: 305
37
Check the glow plugs, they're probably knackered.
I know many will say HDi's don't need glow plugs to start which is true, (they don't pre heat unless the ambient temperature is low) but the glow plugs do come on after the engine is started to reduce cold engine emissions and to help the engine to warm up.
• Sparky_UK
Thanks Given: 5
03-10-2024, 04:56 PM
Thanks for your replies.
I dont think it has Eolys, not sure. Ill take a look tomorrow.
Threads: 8
Thanks Given: 305
37
I don't believe any of M59 1.6 hdi's had a DPF fitted so no Eolys system . . . not sure how that happened, maybe something to do with when the vehicle was manufactured ?
• Sparky_UK
