Thanks Received: 1 in 1 posts
Hi I have a 2010 Multispace XTR
a friend is scapping his 2010 multispace which isnt a XTR...question is would his tow bar fit my XTR without modification or do IU have to find one that is specific to XTC?
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 166
21
(03-10-2024, 08:44 AM)k5d2003 Wrote: Hi I have a 2010 Multispace XTR
Should be fine
Just source some new high tensile bolts using The old
Ones as patterns
The spacer tubes may have deformed a bit so check those too
Thank you for that I was wondering if the chassis were the same or different....looks like Im going to be busy
The following 1 user says Thank You to k5d2003 for this post:1 user says Thank You to k5d2003 for this post
• evdama
