  • 11 Vote(s) - 3.27 Average
[Transmission] sensor drive
valeo 616070speed sensor drive shaft
does anyone know of a supplier or a part number
Year? Engine?
We do like introductions too:wave:
(31-05-2012, 10:37 AM)Coco Wrote:  Year? Engine?
hi , i'm a berlingo owner {03 1.4 multispace} and got a new clutch fitted after which speedo failed . checked fuses , reset bsi , fitted a new sensor {mechanic says drive to sensor broken from crankcase pinion} will fit for a tenner if i can find part . tried all over including renault suppliers . loath to put car into local citroen dealer to get --- hillian
Does it look like this?
This is for the MA gearbox. If it is different you will have the BE4R box
Attached Files Thumbnail(s)
  • taxi
(31-05-2012, 02:31 PM)Coco Wrote:  Does it look like this?
coco , i have tried to id gearbox but cant seefrom below because of sump guard,tried taking out battery and tray but couldn't see around engine , fired berlingo ma gearbox into google and ebay lisings came up for 1.4 and 1.6 crankcases..it looks like the ma canbe sorted if i can get part and if i remember from as- search i did the be4r hasto have a crankcase strip. i guess have to bite the bullet and take it to citroen
Hi, if you PM me your Vin No. I might be able to help. Confusedtudy:
[-] The following 2 users say Thank You to Rustscrat for this post:
  • hillian, taxi
(31-05-2012, 06:12 PM)Rustscrat Wrote:  Hi, if you PM me your Vin No. I might be able to help. Confusedtudy:
hi rustcrat
vin no vf7gjkfwb93037859
got it from reg document
Can you check that VIN please? I'm not getting any joy with it
  • hillian
Hi,Your g/box is listed as an uprated MA type. I'll PM your serial No. to you.
The pinion that you require (item No.2 in Coco's post) is Citroen Pt. No. 2649 17.
This is not the first time someone has posted a fault like this after having there clutch replaced by stop in centers.
I'm presuming they are not taking care when reinstalling the drive shafts which breaks this plastic part.:censored:
Let us all know how you get on.Confusedalut:
  • hillian
(01-06-2012, 02:09 PM)Rustscrat Wrote:  Hi,Your g/box is listed as an uprated MA type. I'll PM your serial No. to you.
your an absolute star ..will order part asap-- many many thanks to you and also to coco --hillian
[-] The following 1 user says Thank You to hillian for this post:
  • Rustscrat
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
