Threads: 5
Thanks Given: 1
13-10-2024, 08:34 PM
(This post was last modified: 13-10-2024, 08:36 PM by oldbird.)
For sometime now, I've been noticing that my power steering fluid needed topping up fairly regularly. I pointed it out to my garage and they said "no leak"....twice. Eventually I noticed some spillage on the ground, roughly behind the first 2 digits of the registration plate.
With the new information, the garage finally found the leak and informed me that it was a main dealer part only and would take around 3 hours to fit. As my garage (and me) are in France, sometimes things can be lost in translation, but he said he would get me a price for the part, but it would be expensive. That was several weeks ago and despite 3 emails, he's failed to come back to me with a price for the part, which is out of character, as he's usually pretty good. He knows that I'm on a tight budget and I'm beginning to suspect that the reason he hasn't got back to me, is that this is going to be bad news.
Has anyone had experience of replacing power steering, or could anyone give me an idea of price. ? My van is a 2007 1.6hdi Berlingo.
Threads: 67
Thanks Given: 238
50
14-10-2024, 04:52 PM
(This post was last modified: 14-10-2024, 04:53 PM by geoff.)
Difficult to answer your question without more information.
What part did the mechanic say needed replacing ?
Have you got a photograph of the leak and its location / component leaking ?
IF by chance the pump is leaking then this is the time to get the timing belt and water pump replaced since you'll need to remove the timing belt to get the pump off ... that is an IF the pump is at fault.
If the power steering rack is leaking then why not fit a second hand one for a lot less money, well you did say that cash was in short supply Lol.
DIY any good to you ?
Keep us updated with your progress please/
Serieal Berlingo owner
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
[quote="geoff" pid='164207' dateline='1728924758']
I always thought the steering pump was auxiliary belt driven , must be out of touch.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 67
Thanks Given: 238
50
I'm officially a KNOB !!!
Yes aux belt ..... sorry .......................
Threads: 5
Thanks Given: 1
Hi Guys, sorry it's taken such a long time to reply. Life kind of got in the way. Turned out it was a leak on the actual pipe. I contacted a UK main dealer and they sent me a parts diagram for the full power steering system. I waited 9 months for delivery of the of the replacement piece of pipe from the French supplier and in the end, I've had to get one from Poland! It's finally being fitted next Wednesday, along with suspension arms and a service. No doubt something else will need fixing soon. Watch this space. ?
Threads: 67
Thanks Given: 238
50
Thanks for the update ..........................
