Berlingo MAX M Diesel 2024 - removing load retaining partition
I hope this is the right place to ask ...
I've just taken ownership of a new Berlingo and I'm unnerved. It has what I think is called the 'load retaining partition'; a pretty functional steel separator between the rear seats and storage. I assumed it'd be straightforward to remove but it looks well bolted in. There's a tiny little plastic tool clipped to it that doesn't seem to do anything useful and I can't match up the diagram to anything. I can't find any instructions on how to remove it. Do I just unbolt it and is it ok to do so? I had a Berlingo Flair about 8 years ago and it was nothing like this!
Attached Files Thumbnail(s)
It's very easy to remove. Just remove the upper and lower bolts plus middle clamps from the partitition and lift it off the hooks. Have a friend help you to slide it out. It's bit tricky. I've done it many times so I can do it alone.
You'll have two protuding bits left on the floor, just unbolt these as well and put in storage. The roof hooks can be left in place and used as bungee cord attachments or something. Or remove completely.
The yellow key is for unlocking the rear hatch from the inside I think.
ex: 2003 1.4i cargo
[-] The following 3 users say Thank You to boop for this post:
  • alan brown, dougienisbet, Matt Haigh
(15-10-2024, 10:19 PM)boop Wrote:  It's very easy to remove. Just remove the upper and lower bolts plus middle clamps from the partitition and lift it off the hooks. Have a friend help you to slide it out. It's bit tricky. I've done it many times so I can do it alone.
Thanks for this. I really appreciate it. It's just what I was looking for, a simple guide. It didn't look particularly complicated but I'm a bit nervous never having owned a brand-new car before and all the little things are making me a bit anxious. It looks so much better now, and no longer feels like a prison van.
[-] The following 1 user says Thank You to dougienisbet for this post:
  • boop
Just remembered. When removing the floor bits, put the bolts back in as these penetrate the floorboard and you'll have water creep in if left open.
ex: 2003 1.4i cargo
[-] The following 1 user says Thank You to boop for this post:
  • dougienisbet
(16-10-2024, 03:25 PM)boop Wrote:  Just remembered. When removing the floor bits, put the bolts back in as these penetrate the floorboard and you'll have water creep in if left open.
I'll check this tomorrow. It wasn't a difficult job in the end and yes, I ended up putting the roof brackets back into the roof as they're handy, albeit unsightly, for hooking on bungee cords to help keep the bikes in place.
Berlingo until 2018 then a Skoda Yeti, now back to Berlingo:
Berlingo 1.5 BlueHDi 130 Plus M EAT8 Start+Stop 5
Out of interest, what does your V5C document say for Body Type and Vehicle Category?
I've a suspicion it might say LGV and N1, based on the presence of the metal bulkhead. Previously, passenger Berlingos were classed as MPV and M1.
Thanks.
Yesterday 07:31 AM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
OIL Drip
Last Post: Martinze
10-03-2026 06:08 PM
10-03-2026 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
