New Driveshaft issues
Hello
Having issues with getting the right driveshafts
2016 Berlingo with the 6 speed semi auto box ( not sure what its called STT SST etc )
Fitted brand new genuine PSA oil seals
Parts checkers confirm fitment
All of the driveshafts I have got so far dont fit ! 2 sets so far
Asuming I'm recieving 5 speed ones ??
Nearside have been approx 10 - 15mm too long where it goes into the diff & hit a pin/rod
which wont allow it to go into the oil seal .
Offside with intermediate bearing ,The seal shoulder appears to be too far down the shaft so it leaks .
In total I have now drained the gear oil 5 times on this job !
Also it doesn't have the level plug on the side only the top vent plug for filling which is an additional pain .
Anyone had this issue ?
Did my 5 spd manual 2012 P Partner last year no issues whatsoever .
Will post pics when I get them out again ( raining )
(19-10-2024, 09:39 AM)raymondinio Wrote:  Hello
All of the driveshafts I have got so far don't fit ! 2 sets so far
Assuming I'm receiving 5 speed ones ??
When you say parts checkers confirm fitment, what parts checkers are you referring to? The one's that use registration plate on various part sites can be very hit/miss. Have you tried using the catcar info site and inputting your VIN into the site to get to the parts catalogue for your vehicle?
I found that to be very good at locating the correct p/n for various hard to find parts for my Berlingo Multispace [B9]
https://www.catcar.info/citroen/?lang=en
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • raymondinio
I presume catcar is either just for older models or not for German models as my VIN doesn't work.
I have a 1.2 petrol K9.
Now a 2019 K9 1.2 petrol.
(21-10-2024, 01:03 PM)Mark604 Wrote:  I presume catcar is either just for older models or not for German models as my VIN doesn't work.
Not for K9, only for the vehicles listed/pictured on the main Citroen page that I linked to.
_______________
Not a Citroen  Cry
  • Mark604
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
