2011 B9 radio change possibility
My 2011 Partner Tepee B9, only have a display screen like the first photo, it is very simple and no aux, no bluetooth. So can I change the radio to something like the second one to have more functions? Will it fit the 2011 model? As I see this device is equipped on models after 2012 facelift. Thank you.
Attached Files Thumbnail(s)
2011 B9 1.6diesel 112bhp
(21-10-2024, 02:08 PM)IKUN Wrote:  My 2011 Partner Tepee B9, only have a display screen like the first photo, it is very simple and no aux, no bluetooth. So can I change the radio to something like the second one to have more functions? Will it fit the 2011 model? As I see this device is equipped on models after 2012 facelift. Thank you.
Looking at the various replies from previous asks, yes it is possible but it needs coding to your vehicle otherwise it will not work. If you search the forum using just the word radio and then look at the replies for the B9 model it will give you an idea.
A couple below:
https://www.berlingoforum.com/thread-235...ight=Radio
https://www.berlingoforum.com/thread-234...ight=radio
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
General consensus here on the forum a few years ago was that while it was possible to upgrade to the higher spec radio unit a better (and likely cheaper) option was to install an aftermarket Android unit. A forum search will bring up the discussion and links to several installation experiences.
Good Luck
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
I'd debate that slightly.
I've bought an RD45, display etc for £55, and will probably sell the RD4 on eBay to recoup a few £.
Main thing is - unless the seller will code it for you, you MUST have a copy of Diagbox for this to work. If you don't already have that, the finances get much closer to a cheapish android unit plus some interface boxes.
All I wanted was a cheap way to play MP3s, stream music from my phone, and have handsfree, I already have Diagbox, so a net £30 plus some of my time is fine for that.
The other simpler and cheaper way is to replace the original RD4 radio with a more advanced aftermarket radio like Pioneer. You will need to add a CanBus decoder Connectis2 from Ebay and an adapted to antenna wire "Fakra male to DIN".
In this way, all the functions that were controlled from the original radio (clock set, date set) will move to a control stalk under the steering wheel.
More pics - Fakra antenna adapter and the aftermarket radio installed.
No coding needed.
Thank you very much everyone. Sorry I had a due in the past days so I didn't respond at time. Thank you for your advice, it is so complex and I will buy some CDs and a CD burner instead lol.
If you push the source button do you get an AUX come up , have you got 2 din sockets in the glove box?
(05-11-2024, 02:22 PM)Wightlingo Wrote:  If you push the source button do you get an AUX come up , have you got 2 din sockets in the glove box?
Yes, but I don't think I have any devices that can adjust that 2 din sockets in 2024. I remember such sockets only appear in childhood memory.
 You can get a phono to 3.5 mm jack plug lead , I have one that I use to listen to music on my phone or a small Roberts DAB radio.
https://www.ebay.co.uk/itm/261111240146?...0162107850
[-] The following 1 user says Thank You to Wightlingo for this post:
  • IKUN
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
