Changing a bulb shouldn’t be too tricky right?
Decided not to pay Halfords to fit new dipped headlight bulb. How hard can it be right?
Well, it removed the bulb ok but can’t get the new one to stay in place.
Manual says to turn it then pull it out. I found it hard to turn but gave it a bit of a wiggle and it came loose.
Replaced the bulb
Now can’t get it back in. Can’t get it to fit and then if I do think it’s sitting in ok and can’t turn it then it comes out.
Does anyone know a trick to try is? Have I damaged it getting it out.
I’m doing this from the inside, under the bonnet so can’t see a thing.
You tube ???
Searching YouTube.
Can only seem to find videos for the previous generation models.
[-] The following 1 user says Thank You to Galagemm for this post:
  • geoff
This might be of help?
https://youtu.be/YNbasWcOEP8?feature=shared
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
I believe that the low beam bulb in the K9 is an H7
Here is a generic H7 video that clearly shows how to remove/reinstall
https://youtu.be/fRpmO5YomC4?si=r5PbU6F0E-Cla1AV
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
