Threads: 6
Thanks Received: 2 in 2 posts
Thanks Given: 10
My 54 plate 2.0 HDi Berlingo goes into limp mode on a hard acceleration. The code is p1198. I assumed it was due to the fuel pressure sensor, but apparently not. ( I read that the car should run with the fuel sensor unplugged but it's immediate limp mode with p0082 and p0093 codes, which I cleared). There is what I think is a cold start valve on the right side of the fuel rail. I unplugged that and the car seems to run normally. Can anyone make sense of this, and if it is this valve is it easy to change?
Any insgiht welcome.
Threads: 6
Thanks Given: 10
Latest. I changed the fuel pressure valve and the cold start valve. No improvement. It threw up codes p1198 and p0087, indicating a fuel pressure issue, Also new fuel filter.
Thanks Given: 39
13
I picked up from Dispatch forum that there is a pump in the diesel tank (on dispatch 2.0 hdi.).
Maybe that could be weak if berlingo has similar system..
Threads: 6
Thanks Given: 10
Apologies for not updating:
The problem was the O ring in the fuel filter housing not sealing properly!
The following 1 user says Thank You to Jehu40 for this post:1 user says Thank You to Jehu40 for this post
• RJBingham
