Water inside door
Hi all
I seem to have water inside my passenger door somehow, I noticed a sloshing sound ages ago but thought a bottle of water must have gone rogue and got trapped somewhere but on opening/closing the door realised it was in the door. Now and again when I'm parked on a hill it trickles out
I assume it's a seal issue but no idea which as they look ok
I have added wind deflectors a while ago so possible it's those?
Any ideas and how do I get it out
Cheers any help appreciated
There shouldn't be enough water in there to slosh about. I'd start by having a poke at the drain holes with a cable tie or something, get the water to drain out.
[-] The following 1 user says Thank You to shtu for this post:
  • shawstvs1
Exactly, there are drain holes on the bottom edge of the door, behind the rubber seal.
They are probably clogged. Try to clean them with a small screwdriver or something similar.
[-] The following 1 user says Thank You to Buki for this post:
  • shawstvs1
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
