Threads: 8
Thanks Received: 1 in 1 posts
Hi,
On longer drives the drivers seat in my Berlingo van is starting to give me some pretty bad back ache.
Based on other cars it feels like it's the lack of under thigh support that's causing it but could be wrong.
Anyone else have a similar problem?
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
I had the same thing with my Multispace B9. It ended up I had to put my fist in between my back and the seat to get some relief on long journeys. I knew what the problem for me was though and it was not having a cruise control. Now I have on my K9 I do the same journeys without a problem.
Now a 2019 K9 1.2 petrol.
Threads: 13
Thanks Received: 2 in 2 posts
Thanks Given: 15
For my B9 Partner Tepee with cruise control I also find the same problem. I didn't feel back ache until I use it for a long trip to Italy and I drove for whole day long. I think it is because my body is a little bit tilt to the front without notice when driving and my back is not fully fit to the seat back. I find that I can adjust the angel of the seat back a little bit to make my back fully fit to it can solve this problem. If I just take a rest and make my whole body fit to the seat I think the seat of Partner Tepee/ Berlingo Multispace is even as comfortable as some D-segment cars, but its angel and the support of the seat back is a little bit weird for me to adjust, and for me the seat back angel need to be smaller than passenger cars.
2011 B9 1.6diesel 112bhp
Threads: 8
Just following on from this, does anyone have the part codes for the drivers seat squab/base?
I recently sat in another van with a lot lower miles and came to realise how flat and unsupportive mine is. Might be worth a shot as the aching is getting worse!
Threads: 85
Thanks Received: 399 in 341 posts
Thanks Given: 179
22
It could be the seat is exacerbating an existing condition.
I'm plagued with back injuries from foolish younger days and find if I occassionally release the corroded jubilee clips from my wallet and visit the osteopath I come away with freely moving parts for a year or so
Threads: 6
Thanks Given: 6
I was uncomfortable driving my multispace when I first got it, left leg was in an uncomfortable position due to the polystyrene block under the carpet on the lefthand side, mines an auto. So up come the carpet & out come the block of foam, driving now is so much easier as I can extend my left leg fully especially on long journeys, coupled with cruise control is a breeze.
I never got a bad back, didn't have the foam block in long enough, but it's defo worth a try.
