Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
Accept my apologies but I just cannot find reliable information (apart from going to a Dealer which is quite a distance away from me) as to how often the timing belt should be changed on my K9 1.2 PureTech 110 S&S BVM6, Code EB2ADT MB6 STTD.
I have the VIN if needed but it is a German car so it may be different than can be used on UK websites.
I'm seeing that the interval changed recently(?) but anywhere between 60,000 miles/km to 240,000 miles/km, but it that for a belt or a chain?
I have a belt I understand, no?
Now a 2019 K9 1.2 petrol.
Threads: 67
Thanks Given: 237
50
Mark, can you telephone the dealership instead of driving ?
Serieal Berlingo owner
Threads: 19
Thanks Given: 12
16
Aha! You've spotted the flaw in my plan. I would have to ask someone to do it for me as those that answer the phone have very little English and my German isn't good enough to convey technical things. Though I wonder now if modern technology is good enough over a phone to use Google Translate. I could probably get the initial question conveyed but then I get a bit stumped with the replies. In the garage face to face the translate thing works resonably well.
I was hoping one of the members, maybe with the professional experience though not necessarily, could just say off the top of their head.
Threads: 67
Thanks Given: 237
50
24-11-2024, 07:22 AM
(This post was last modified: 24-11-2024, 07:22 AM by geoff.)
Ah sorry, I wasn't aware of the language barrier .... oh well at least teh topic has been bumped up the list, good luck !
Threads: 5
Thanks Received: 12 in 12 posts
4
(24-11-2024, 05:40 AM)Mark604 Wrote: Aha! You've spotted the flaw in my plan. I would have to ask someone to do it for me as those that answer the phone have very little English and my German isn't good enough to convey technical things. Though I wonder now if modern technology is good enough over a phone to use Google Translate. I could probably get the initial question conveyed but then I get a bit stumped with the replies. In the garage face to face the translate thing works resonably well.
Can’t you just ring a Citroën Dealer in the UK?
Or use their online form?
https://citroen.my-customerportal.com/citroen/s/case-webform?language=en_GB
I doubt they make the engines differently for each country.
2016 Berlingo Multispace XTR BlueHDI 100 BHP
2010 Berlingo Multispace XTR HDI 90 BHP
Threads: 19
Thanks Given: 12
16
Geoff, thanks.
David, yes, I'll try that as well. See what happens. Though on some of the spare parts websites used in the UK my VIN is not found. I wouldn't expect that to happen with Citroen direct though.
Threads: 19
Thanks Given: 12
16
David, just filled out that request form and it asks for the VIN. The form spat me out saying the VIN "Your entry does not match the allowed pattern." Well, it is a VIN and been used in Germany a number of times as an identifier. Nevertheless though I avoided now that box, put the VIN in the main text and the information request went through.
Threads: 4
Thanks Received: 11 in 9 posts
Thanks Given: 1
A good question. The 1.2 engine has been used by PSA for several years and is now on (at least) the third timing belt design. A recent article in Car Mechanics on the subject of changing the 1.2 timing belt suggested that timing belt life was reduced by contamination of the oil caused by infrequent oil changes, the wrong oil grade, short journeys and the use of the Stop/Start system. So what is the current recommendation from PSA for the belt fitted to K9 vehicles?
Threads: 19
Thanks Given: 12
16
A person asked on the Frenchcarforum about his timing belt and oil specifications. He has a 2019 Grand C4 Spacetourer with a 130hp 1.2 petrol. The answer given was "...engine variant (EB2ADTS).
The timing belt is 64k miles / 6 years, then every 128k miles (likely as they will be replacing it with a third generation belt)."
Mine is the 110hp version but is also a 2019 and variant of EB2ADT (no S..) - which means I have no idea.
https://frenchcarforum.co.uk/forum/viewt...hp?t=81632
Threads: 19
Thanks Given: 12
16
Update - went to the Citroen dealer/garage this morning (with Google translate).
They took all the car details, plugged them in to their database, the man went in the back to speak to the chief mechanic, came back and said - needs to be changed at 100,000km (approx. 62,000 miles) or after six years.
I need to get mine done.
Asked as to price - he said there is a complete kit that costs about 200 Euros. But, don't have one so they'll order it but not sure when it will come, if it does at all - before the appointment I've later made for December 10th.
If it doesn't arrive they have the different bits separately but it will cost more.
How much, I ask.
Twice the price, so 400 Euros.
And how much is labour?
350 Euros.
So it will cost between 550 and 750 Euros?
No, there is 19% tax on top.
At that point I fainted.
When I woke up I decided I'll sell all my possessions, get the car done and then sleep in it for all eternity until I maybe can sell my body to rent a hovel somewhere.
The following 2 users say Thank You to Mark604 for this post:2 users say Thank You to Mark604 for this post
• boop, geoff
