Oil around intercooler + low oil warning
Ever since the vehicle was serviced at a garage, there has been oil around the intercooler.
Just got the oil warning light again after topping out a few weeks ago.
If its just oil around the intercooler, could be just the intercooler, right?
If there is an oil low warning too, must be something more serious like the turbo?
I am trying to get the garage to tell me which oil was used, as if they used the wrong one, it may have messed with pressure?
The oil used will not have much effect on the oil pressure, check all the hoses around the turbo and that the oil filler cap is on tight.
(29-11-2024, 09:30 PM)Wightlingo Wrote:  The oil used will not have much effect on the oil pressure, check all the hoses around the turbo and that the oil filler cap is on tight.
The tube coming from the crankcase to the turbo has oil in it. More than just a mist.
The tube from the turbo going to the doser? then intercooler has oil in it.
Not sure where it is coming from.
Turbo shaft has no play, no strange noises, good performance.
Last service they used castrol 0w30 apparently. Guessing thats not a low saps oil.
No visible oil leaks elsewhere other than the intercooler. Second oil low warning light after another 2k miles in two months
63k miles.
Last Post: mikeh79
Yesterday 07:00 PM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
