[Engine] engine alarm and lumpy start-up
Hi all, has anyone info or help to offer with my issue:- (my vehicle is 2008 M59 Berlingo 2 1.6Hdi RPO 11418, latterly Diagnostics Lexia3 and Diagbox 7.57) started off throwing engine alarm which came and went and showed as EGR faulty so new one fitted, then start-up became very lumpy/ smokey, but fine when up to temperature. Next test of glow plugs showed 2 faulty ,because of breakage risk, had all replaced by experienced mechanic who then reported glow plug relay as showing faulty. New relay fitted with no improvement to lumpy starting- old relay bench tested and found to be fine( needing glow plug connected to operate) so next to check  positive battery to relay( supposedly 80amp fuse)- no continuity to fuse box. So at a loss decided to refit original relay and test complete circuit at glow plugs now with with Diagbox following result:- Glowplug activation tests looking for 12v at glow plugs (engine cold and not run for 12hours) relay  test 1 12v seen at glow plug, test 2 no 12v seen at plugs, relay heard to operate in both tests( presumedly test 1 is preheat and test  2 post heat ,Engine running? Apparently 12v supply to relay is not solid but via other control circuitry, temperature controlled differently in the two circumstances?
This leads to the question does my engine preheat with glow plugs and then afterheat( till warm) not by glow plugs but perhaps by diesel fuel heating? By the way EGR fault was solved by purchasing a second unit  specifically by part number, not vehicle reg look-up, the position copy sensor circuit being very different value in the first purchased.
All sorted now, was solved by new EGR valve ordered by part number from original which was found to have badly worn bearings in in the top unit, and the new glowplugs as stated. It came to light that Lexia3 and Diagbox 7 was only halfway  in activation testing of the glowplug relay such that second stage relay test operates the relay but does not supply 12volt to the plugs and so misled me. Finally proved by testing for 12volt at glowplugs on an actual cold morning start viz on switch on 12 volt seen for preheat then on start-up seen for c.3 minutes as engine warmed up- all working fine.
[-] The following 1 user says Thank You to BDRichardson for this post:
  • RJBingham
Been a while since I've last done mine, but there is an EGR relearning thingy in Lexia/ Diagbox that's supposed to be done with a replacement EGR valve.
Didn't make much difference to mine, but it's there somewhere.
The glow plugs don't seem to matter much on the 1.6 HDi, unless you have to avoid polar bears.
If they're not working, I think that they get jammed up with soot, which makes them even more prone to snapping.
All the best.
230,000 miles,  (Resurrected at 186,000)
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
