Brake light switch
For a while my brake lights have been staying up up to about 30 seconds after releasing the brake pedal. This is a bit sporadic, and unpredictable. This afternoon, I had my head under the steering wheel and all around the brake pedal - I was told it would be there, and cannot seem to find the switch. Can anyone enlighten me as to where I would find it?
If its a B9 then its on the passenger side below the fuses.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
It is a B9. Why can't Citroen keep things simple?
(02-12-2024, 11:15 AM)LukeC Wrote:  It is a B9. Why can't Citroen keep things simple?
They do keep things simple [if you're French  Wink] What I'm basically saying is they don't move any of the components over to the 'driver's side' on a right-hand drive vehicle if they don't have to.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
I may still have to go digging, where I thought I had rectified the issue with a bit of lube around the brake pedal, I'm now still getting some time staying on. That will have to be a weekend job when I have daylight.
Change the switch - it’s cheap enough and easy to get to, just be sure to get the correct one.
If memory serves it also works in reverse, I.e pressing the brake pedal releases the switch and turns on the brake lights.
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
