[Engine] oil seals
Hello all, does anyone know the size/spec of oil seals  for the camshaft and crankshaft , etc, for the 1600 diesel. M y  B9 is leaking from most of them, and I would like to have the correct ones in stock before I take it out of action, too hopefully save time?   The usual leak from the rocker cover to  the turbo has been sorted by a fresh o ring  and then clamped up with a narrow (Jubilee) clip, that's been in place for over year  and has stiffened the connection up and remained dry!   Thanks for any advice  Tricky
(02-12-2024, 11:03 AM)tricky2 Wrote:  Hello all, does anyone know the size/spec of oil seals  for the camshaft and crankshaft , etc, for the 1600 diesel. M y  B9 is leaking from most of them, and I would like to have the correct ones in stock before I take it out of action, too hopefully save time?   The usual leak from the rocker cover to  the turbo has been sorted by a fresh o ring  and then clamped up with a narrow (Jubilee) clip, that's been in place for over year  and has stiffened the connection up and remained dry!   Thanks for any advice  Tricky
Have you tried looking on the catcar info site for the part numbers of the seals?
Put in your vehicle VIN for the correct parts catalogue
https://www.catcar.info/citroen/?lang=en
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Why not ask the main dealer for price and availability you may find it is an agreeable amount and that way you won’t have worry about correct “ spec “
Yesterday 09:50 AM
» Replies: 16
removing front strut
Yesterday 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
14-09-2026 09:27 PM
Rear seat belt breakage
14-09-2026 04:13 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
