30-12-2024, 09:09 PM
(This post was last modified: 30-12-2024, 09:12 PM by de62.)
Hi, I have just upgraded my berlingo to a K9, it is a 68 plate XTR, on the way home from the garage the wife turned on all the interior fans to check them, the footwell fan does not switch off when i press the button , is this an easy fix or is it a warranty repair?
Thanks Dennis
Threads: 18
Thanks Received: 24 in 24 posts
Thanks Given: 37
You could try a BSI reset. Assume you can do it on K9. I have a B9 and know it can fix electrical shenanigans on this model.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
If you were on your way home after buying it then take it back and get the garage to fix it. Then it will be a warranty repair , else try a BSI reset as suggested.
If you don't how to do a reset then a quick internet search will bring up answers.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
