Drop in fuel economy
Hi, I'm new to posting on this forum.
I have a 2017 , 1.6 HDI Berlingo and my fuel economy has dropped from a normal 58 mpg to a 53 mpg ( so 520 to 400 miles per 3/4 tank) in the last couple of weeks, I'm doing they same journey day in day out on the same road, I've checked the tyre pressures , fluids etc.  Does anyone have any ideas what could have caused this.
Many thanks
                    Gary
It's cold.
(12-01-2025, 08:51 AM)curlywurly1971 Wrote:  Hi, I'm new to posting on this forum.
Many thanks
                    Gary
What kind of mileage has your Berlingo covered? I'm asking as a higher mileage example [or even a low mileage example that only does short journeys] could be suffering from a clogged DPF which can cause MPG to drop. Has the vehicle been doing a number of regens?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • curlywurly1971
Many thanks
                    Gary
Hi Multispacer,
My car has just gone over the 86000 mark and I normally do journeys to work of 25 miles each way, 4 times a week, with a short trip shopping of 10 miles each way once a week. I nearly all of my journeys on a main A Road doing 60mph.
                Gary
Binding brake caliper?
  • curlywurly1971
Many thanks
                    Gary
I agree with Evdama and possible binding calipers, have had that affecting MPG a few times over the years, especially in winter due road salt etc.
Also agree with Shtu about the colder weather in general - and then consider it could be caused by ‘winter diesel’ being used just now in the UK, some folk suggest that increases fuel consumption slightly..?
[-] The following 1 user says Thank You to Teep for this post:
  • curlywurly1971
(12-01-2025, 10:44 AM)shtu Wrote:  It's cold.
Totally agree with this - last week temps most days were below 0 degrees, even the older B9's take a good 10 miles to warm up. Also don't forget diesel fuel will be on its winter grade now and wont be as efficient
[-] The following 1 user says Thank You to Tree for this post:
  • curlywurly1971
Every day is a school day, I never realised that there was such a thing as winter diesel.
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
