i have installed a towbar and used a towbar module from a scrapped berlingo into mine.
i have put in a 40amp fuse in the fusebox under the battery.
so the wire went live.
measured 12v going into the module.
the berlingo was prewired for a towbar. so the module was just to plug in.
Yet the electric does not work.
i drove to a dealer but he plainly said over the counter it does not need activation because its a older car.
Is this correct ?
or was that guy wrong and do i need activation in the cpu after all.
its a berlingo b9 2009 multispace
its a 7 pin towbar
Is this correct ?
its a 7 pin towbar
