  • 8 Vote(s) - 3.5 Average
Glow plug ignition light
Hi folks,
i have recently joined the forum and have found just about everything i need to service my 1.6 HDI before she becomes a small camper van... i.e
  • oil, fuel and air filter change guide lines in the how to section
  • alloy wheel size and fitment in the general forum
  • service intervals in the MK2 forum
I am greatfull for this info.
I am however confused about the glow plug light, in the past deisel engines i have owned i turn on the ignition and wait for light to go out and then start.
My berlingo van does not seem to have a light, is this normal for the model of van...? (1.6 hdi enterprise 2006/7)
Also can i purchase an engine cover for under the engine as my van does not seem to have one fitted as standard.?
Any help with theese issues would be greatly appriciated.
Thanks....Dave
Glow plug light only comes on when temp is zero degrees.
[-] The following 1 user says Thank You to steve valentine for this post:
  • drussell7299
Hi,
Thanks for the info, i thought it may be something like that.
Ill get to test the theory as I live in inverness so will prob be zero degrees at some point this summer...
Thanks...Dave
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
