Rear brake caliper piston problem
Hi everyone
I have a problem with the rear brake caliper piston
I was using a wind in tool (see attached pic) and could not get it to move, so I used a pair of mole grips and managed free it by turning it back and forth, but while doing this, it has pushed the piston out, dont know why its done this because I wasnt turning it just one way
I know the seal is missing, and I have a kit to replace it, but for the moment I just want to push this one back in and dont understand whats stopping it
Any advice very much appreciated
legepe
Attached Files Thumbnail(s)
I believe that the rear caliper piston screws back into the calpier. It will not push in.
There is a large screw in the centre which is worked by the h/brake. When you used mole grips you probably screwed the piston out.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
You could have the remains on the dust seal (the seal that is missing) still in place which is jamming the piston somehow.
The piston should push in by hand past the fluid seal (the square cut seal that fits into the groove in the bore of the caliper) Once the piston is in past the fluid seal it should screw in (clockwise) easily with the tool you are using.
Looking at the state of that piston, I'd probably bin and replace it.
You can buy brand new ones from not-awful brands (Febi) for £35-40, decent-looking used ones about £20.
(13-02-2025, 08:47 PM)shtu Wrote:  Looking at the state of that piston, I'd probably bin and replace it.
Were you using the correct tool?
The b9 piston winds back clockwise.
engine light
Yesterday 01:00 PM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
