Headlight replacement b9
]I need to replace os mk2 2008 headlight as its fogged tried cleaning/polishing and no better
My part number is as first photo
Parts I've found as in second image
Will it work? I've replaced passenger side with a 2016 but with same part number and all OK as expected
Any info much appreciated
Cheers
Attached Files Thumbnail(s)
Brand new ones are given the same part number for the entire production run '08 to '18 suggesting it should be fine.
As long as the motor still works and it aligns.
I assumed it would be compatible but needed a more knowledgeable opinion
Many thanks
Last Post: BDRichardson
Today 04:07 PM
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
