Battery State of Charge unit wiring
Hi All,
2014 1.6 HDI B9 Berlingo Multispace.
My battery hasn't been charging properly, I did a bit of investigating & I had DTC F066 "No communication with battery State Of Charge (SOC) unit", after a bit more work I found that I have a poor connection on the 12v supply to the battery SOC unit (only 2v with the unit connected, rising to 11v when the unit is disconnected).
Does anyone have or know where I can get a wiring diagram to showing where the 12v feed comes from, please?
[-] The following 1 user says Thank You to Limbs for this post:
  • berlingo_b9_2ndgen
In case anyone else reads this in the future, the unit is fed from a 5 amp fuse located on the fuse board that's mounted on top of the battery cover, my problem was a slightly corroded fuse, I replaced this and cleaned the terminals and all is good.
  • Drummond
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
