MK1 Berlingo multispace (2003) wont start!
Hey, please help..
I have a 52 plate multispace. I went to start it yesterday and it will crank but wont start.
I tried again, this time in first gear with clutch down and tried to rev as I turned the ignition and it did move forward as I hit the biting point but still wouldn't start. Topped up fuel but that didn't help.
It's not the battery but after trying again to start it 5 more times, it's now not cranking properly, like sounding very sluggish as if the battery has been drained.
I'm struggling to find fuse diagrams. I am not a mechanic but I've changed basics like my exhaust... Wiper pump, brake pads etc. I am skint (!!) and desperate to find a solution myself because I rely on the old girl for work and school... Please any ideas would be appreciated so much.
What do I need to check? It's not bringing up any fault codes. I have a multimeter but I don't know where to begin trying to diagnose this.
 This has pretty much come on suddenly, I hadn't driven for 3 days, it has started reliably until last week out the blue it cranked but didn't start on first attempt, but started second try. That was on Saturday - wednesday (yesterday) turned over but not starting and same today and battery is draining. Not sure if that's purely down to trying to start the car several times or if the fuel pump relay is an issue? Thanks any advice is REALLY appreciated.
Have you measured the battery charge with the multimeter?
[-] The following 1 user says Thank You to notsofast for this post:
  • Beaumotor
(20-02-2025, 08:20 PM)Beaumotor Wrote:  Hey, please help..
I have a 52 plate Multispace. I went to start it yesterday and it will crank but wont start.
 This has pretty much come on suddenly, I hadn't driven for 3 days, it has started reliably until last week out the blue it cranked but didn't start on first attempt, but started second try. That was on Saturday - Wednesday (yesterday) turned over but not starting and same today and battery is draining. Not sure if that's purely down to trying to start the car several times or if the fuel pump relay is an issue? Thanks any advice is REALLY appreciated.
Some more info would be good to help with possible causes/solutions.
Petrol or Diesel?
Engine size?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Beaumotor
engine light
Yesterday 01:00 PM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
