Threads: 41
Thanks Received: 82 in 75 posts
Thanks Given: 129
9
Well the smoke isn't just coming out of the exhaust, which suggests you've got a hole or leak somewhere. Are the oil and coolant levels normal?
Threads: 41
Thanks Given: 129
9
Have you inspected the exhaust to see where it's leaking? As well as the coolant level, I'd check there isn't oil getting into it nor any bubbles of gas while the engine is running (obviously start from cold - don't remove coolant filler cap if engine already warm).
The following 1 user says Thank You to notsofast for this post:1 user says Thank You to notsofast for this post
• Augisu
Threads: 41
Thanks Given: 129
9
What's happened to this thread? I wrote at least 2 replies yesterday.
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
There were two threads , I.ve merged them .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 26
Thanks Received: 31 in 28 posts
Thanks Given: 8
9
White smoke, smells sweet; head gasket, cracked head.
White smoke, smells of paraffin/ diesel; air in fuel, (air getting in the fuel pipe as the injection pump sucks fuel from the tank?
227,00 miles, (Resurrected at 186,000)
