07-03-2025, 11:22 AM
Issue:
After BSM replacement the headlights switch on & remain on after locking doors.
Background:
My Citroen Berlingo, as detailed below, developed a relay fault - it was continually opening & closing very fast as identified by a very noticeable clicking sound & a multitude of fault codes appearing (clearly related to a lack of a good 12V power supply).
I replaced the original BSM with a new recommended updated model BSM.
I cleared all the fault codes & performed a BSI reset.
Everything worked fine in the car until I locked the doors- as the electronics were ‘settling’ the headlights flashed intermittently, then once the electronics fully ‘settled’ the headlights switched on & remained on.
I have done multiple BSI resets as advised on here & nothing changes.
I swapped my original BSM back in & the headlight issue was not there.
Putting the new BSM in just recreates the headlight fault every time.
Questions:
Have you replaced a 9675878280 BSM with a 9807028780 BSM?
Did it cause any issues?
Have you experienced the issue as described in any other circumstance?
How did you resolve it?
Thank you for reading this.
Vehicle:
Year: 2013
Make: Citroen
Model: Berlingo M-SP AIR XTR E-HDI SA
Engine Code: DV6DTED (9HP)
BSM:
Original BSM part letters/numbers;
9675878280 BSM-R04-00 12/06/13
Replacement BSM part numbers;
9807028780
Background:
Questions:
Vehicle:
Year: 2013
Make: Citroen
BSM:
9807028780
