Driver's side electric window dead
The driver's side window control doesn't move the window when you press it. I hoped it was a fuse but the passenger-side window works fine (apart from the usual loud screeching).
Is there anything a non-technical owner like me could look at to diagnose/fix this before taking it to a garage?
It's recently been in for some work but I hadn't tried the window until a week after so I don't know if it's as a result of that or not.
My car: 2012 Citroen Berlingo Multispace XTR - 1.6 HDI 7J9HP
(08-03-2025, 05:07 PM)robjwood Wrote:  The driver's side window control doesn't move the window when you press it. I hoped it was a fuse but the passenger-side window works fine (apart from the usual loud screeching).
I had that problem, put new switch in and bingo, that was a few years ago and sme problem has appeared byt there cheap one from that doc company. in for a serv ice net week so will ask them to do it as it's a bit tricky.
there are videos on it, i think i posted one on here
2009 1.6HDI with AC
I think this is the one you mean: https://www.berlingoforum.com/thread-22382.html I'll take a look, thanks.
To be honest, even if I manage to get to switch panel, I don't really know what I'd be looking for. Would I need a kit to test any of the connections or am I likely to see something broken/out of place?
I'm a complete novice when it comes to switches and anything electrical!
(09-03-2025, 06:10 PM)robjwood Wrote:  To be honest, even if I manage to get to switch panel, I don't really know what I'd be looking for. Would I need a kit to test any of the connections or am I likely to see something broken/out of place?
If like mine it's just a knackered switch then it's a straight change
IIRC it's just plug the connectors in to the electric  socket on the back of switch
2009 1.6HDI with AC
[-] The following 1 user says Thank You to magoo1 for this post:
  • robjwood
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
