TPMS Issue
My daughter's 2016 Partner Tepee has started flasing up the message 'Under Inflation Monitoring Fault' when first switching on the ignition. The message goes away after about 2 seconds. I've checked the pressures and confirmed the pressure reset in the menu, but the message re-appears after a while.
Does anyone know it this model has TPMS valves or does it use the abs to monitor pressures?
If it is the valves, can you get them replaced without going to a main dealer?
Cheers,
Mark
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Tyre shop can replace valves and sort any electronic shenanigans should they arise.
We have a contract with ATS for our work vans and they resolve the constant TPMS issues from the mobile workshop
  • MarkT
(10-03-2025, 05:37 PM)evdama Wrote:  Tyre shop can replace valves and sort any electronic shenanigans should they arise.
Thanks @evdama, I was hoping that would be the case.  I really wanted to avoid the dealer's 'premium' pricing.
Tell me about it
Mot failure yesterday
Cv boot clip needed replacing
Twenty quid...
Wire through bulkhead
Last Post: Jakejjt
Today 05:25 PM
Loose tailgate spoiler
Today 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
