Anti corrosion spray
Any recommendations for a spray other than WD40/Gt85
The van has come back from MOT with the sill coating damaged.
I cant prove it was them.
Id rather not use underseal if possible.
It would also be used under the bonnet nosing where the paint has bubbled off
I used something similar to Tetroseal wax /oil spray, it came with a long extension for the spray nozzle which I could push up box sections and spray. Cant find it now amazon or ebay but it did the job.
Even used it under the bonnet to seal a water leak , the underbonnet heat didn't affect it .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • evdama
Thanks Bf
Ive found something that appears similar -Jenolite
Might give it a go.
Last Post: chrisl
Yesterday 06:48 PM
Cruise control retrofit
Yesterday 05:22 PM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
Anti Pollution fault warning
Last Post: labeline
08-12-2025 01:00 PM
Wire through bulkhead
Last Post: Jakejjt
07-12-2025 05:25 PM
Loose tailgate spoiler
07-12-2025 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
