Threads: 81
Thanks Received: 395 in 338 posts
Thanks Given: 165
20
27-03-2025, 06:11 PM
(This post was last modified: 27-03-2025, 06:12 PM by evdama.)
Id be tempted.
Its not super-overdue.....as long as its done immediately and often thereafter for evermore.
• Duggie12
Threads: 3
Thanks Given: 6
Yeah I guess. It's sort of more the fact there isn't any records of any oil changes in previous years. I guess they were probably done, but who knows...
Sent from my VOG-L29 using Tapatalk
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
3 owners in so few years?
Looks like some well-thought-out shelving in the back, too.
Someone spent some effort putting those together, so why sell it off so soon?
The only real detraction for me would be that there's no window on the passenger-side sliding door. That limits the viewing angle and can be problematic in some intersections.
Threads: 81
Thanks Given: 165
20
Thats why you will see experienced van drivers turn in sharp to meet the give way lines at right angles even though the junction is at an acute angle.
• Duggie12
Threads: 81
Thanks Given: 165
20
Sliding door windows can be a factory fitted option,retrofitted or a door from a car fitted.
Car drivers who are not used to a van will often fall into the trap of the wrong approach at T junctions that are not 90 degrees
Threads: 41
Thanks Received: 82 in 75 posts
Thanks Given: 129
9
Neither of my vans has a window on the passenger side of the cargo area, and although acute-angle intersections require a certain approach - sometimes necessitating a temporary incursion onto the opposite side of the road - usually the worst of these intersections are on fairly minor approach roads with light traffic, so just using care and indicators is sufficient. I do admit though that whenever I approach the 2 tight intersections near me, I always hope there's nobody right behind me and nobody turning into the road I'm on. But I wouldn't have this issue as a consideration when buying a van (and if it were a consideration, it would have to be weighed against the fact that any window in the cargo area provides potential thieves with a presentation of what's on the menu) .
Threads: 3
Thanks Given: 6
I've never had a van so nerver really thought about it to be honest
I've never really seen windows on these vans unless a crew van
And I think I missing something because even if it had a window you wouldn't see anything because of the bulkhead??
Threads: 81
Thanks Given: 165
20
Haha very true!-although bulkheads aren't always fitted as standard.
I had factory fitted windows in the rear barn doors of mine.
Along with that came a rear view mirror on the windscreen ,so the bulkhead option could only be mesh.
