Tie rod end bad almost every year
I replaced both tie rod ends about 3 years ago, 2 years ago replaced them again, now the right one is again bad.. I always put OEM ones but i think they are bad in quality. Please recommend another brand
If you like gaming visit GameForest
I've used Borg and Beck with no problems on M49.
I had similar problems to you with drop links where the synthetic rubber gaiters cracked in a year.
Also drive shaft gaters from local motor factors only lasting a year or 2 which was really annoying as they are a real pain to change
(10-04-2025, 05:52 AM)deejay_xb Wrote:  I replaced both tie rod ends about 3 years ago, 2 years ago replaced them again, now the right one is again bad.. I always put OEM ones but i think they are bad in quality. Please recommend another brand
Do you mean tie-rod ends or drop links? I got through a number of drop links on my Berlingo B9, as this seems to be a weak spot on the Berlingo and a number of other PSA group vehicles but I haven't heard [or seen reports on the forum] of the Berlingo B9 version getting through lots of tie-rod ends?
What brands did you use previously, as that would probably help in people recommending other brands?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
my problem is with the tie-rod end (the link that goes from the direction to the wheel, that is used for wheel align), i always replace them with original PSA ones, but they don't last more than 2 years and i do about 7-8000kms/year
Called Track Rod ends here.
Never found them caused problems with the Berlingo's.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
I think I only ever replaced one track rod end on my Berlingo B9 Multispace and that was because I damaged one when taking the front suspension apart to replace the front shock absorbers and top mounts. I think from memory I used a TRW replacement and I never had any other problems with track rod ends in 8 years of ownership of my 2008 B9 Berlingo [between 2016-2024] My annual mileage being about 22000 kms a year and that was in the UK and mainland Europe.
And as anyone here in the UK will tell you, our roads in the UK have been pretty bad for about the last 10 years!
_______________
Not a Citroen  Cry
I think there may be a different reason that is affecting them rather than buying/fitting bad track rod ends.
Now a 2019 K9 1.2 petrol.
(11-04-2025, 06:08 AM)Mark604 Wrote:  I think there may be a different reason that is affecting them rather than buying/fitting bad track rod ends.
no other problem detected by the dealership mechanic and trust me they are eager to take my money by finding faults..
2 days ago dealership replaced under warranty the track rod end, again with a genuine psa... in the end i had nothing to pay them Smile
(17-04-2025, 05:37 AM)deejay_xb Wrote:  2 days ago dealership replaced under warranty the track rod end, again with a genuine psa... in the end i had nothing to pay them Smile
Good news, that you didn't have to pay for a replacement.
Have all the replacements that have failed been carried out by a dealer/workshop? I'm wondering if the failures are being caused by the fact that a lot of workshop staff seem to use power tools to tighten bolts and maybe they are overtorquing the nut causing damage to the tie-rod end?
_______________
Not a Citroen  Cry
Oil consumption at 200K miles
Last Post: Buki
Today 08:29 AM
Forum activity
Yesterday 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
