[WTB] Wanted - under bonnet insulation pad and brake cylinder screw & washer for 2016 Bling
Wanted - under bonnet insulation pad and brake cylinder screw & washer for 2016 Berlingo II B9 1.6 Blu HDi 100
I lost the oil filler cap and the pad got saturated in oil. Seemingly impossible to clean satisfactorily so looking for a tidy replacement please?
I moved the brake fluid reservoir to improve access to the air filter and dropped a screw & washer. It lodged somewhere in the works and I don't have anything that matches, Can anyone help please?
Many thanks
Brian (Exeter, Devon)
___________________________________________________________________________
Multispace 2016 II B9 04/2008  1.6 BlueHDi 100 - engine  1560cc 73KW 99HP BHY (DV6FD)
I left the oil cap off and it saturated the pad on the cam cover.
Soda crystals and near boiling water got rid of most.
Bear in mind the B9 bonnet rusts from inside so consider a less scrupulous view if possible.
The screw will usually find its way down to the undertray.
For now get a pack of screws from screwfix or your local fasteners outlet or ebay
  • BrianS
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
