AC Compressor Clutch
I replaced my AC compressor clutch last Autumn with an NRF replacement part from AutoDoc.
The AC has stopped working again and even though I haven't had the chance to investigate I suspect it will be the replacement magnetic clutch assembly.
Any one have any previous experience of the success of replacing with a non genuine part or can recommend a manufacturer for a replacement please?
I will test system before i order a replacement to confirm that it is the actual issue.
My Vehicles: 2015 Berlingo Enterprise Van 75 1.6Hdi
                   2021 Nissan Qashqui 1.5DCi
Delphi and Sanden are a couple of names that spring to mind for ac compressor bits.
[-] The following 1 user says Thank You to shtu for this post:
  • tomhick024
(17-04-2025, 08:22 PM)shtu Wrote:  Delphi and Sanden are a couple of names that spring to mind for ac compressor bits.
Cant seem to find what I'd consider well known popular replacement brands for this particular item. Think I might look into a second hand genuine part..
Thanks for the pointer though.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
