[Engine] Part of Dipstick Stuck
Hi Guys, have a problem with a broken dipstick, the plastic tip has broken off and is stuck in the tube. It was the original Citroen part (glass fibre rod). Brought a new one (Citroen), but it wouldn't sit fully into the tube with about 50mm protruding. Tried wire from a stout clothes hanger which pushed the broken part down the tube further but the dipstick still protrudes about 10mm. Tried an electrician's conduit rod (about 4mm diameter fibre glass rod) but it only marginally improved things.
Reading posts on this forum the tube is in two parts, with the broken part of the dipstick in the lower tube part. I've used quite a bit of force to try a clear it with the rod but without success.
The way I see it I could drop the sump and try to clear the tube. Is this lower tube detachable (its probably the only way I could clear the obstruction, to take it off)?
The alternative would be to live with the obstruction and cut say 15mm off the bottom of the dipstick. I've poured a small amount of oil into the dipstick and it does drain into the sump.
Open to advice/suggestions.
1.6HDI
Can you not push it further down with something else into the sump then retrieve it?
With the age if the car I would possibly  go for the alternative
I'd b tempted to try and punch it down into the sump, though something with the right combination of strength and bendiness could be challenging.
Failing that. pull the sump off and pull the bits out that way. Messier, more time consuming, but sure to work.
Radio ariel with the tip cut off or fishing rod section perhaps.
Went for the option of reducing the dipstick length, an oil change was done at the same time. With 148K miles on the clock and approaching the end of its life felt I could live with this modification.
Same problem on a 307 1.6hdi and s
ame solution, I cut a bit of the dipstick and now it goes all the way down.
If the oil level is close to the maximum, it measures ok
If it doesn't go above the average level, it's time to top up.
I don't care if I can't measure the minimum because I should top up before
leave the piece here its is stuck, don't let it be loose inside the engine
I had this problem. I just used a thin bendy hose and pushed it through to the sump. Was about 3 or 4 months ago, a common fault I read!
I suppose you could run around without the undertray and smash the sump pan.
Ideal opportunity to push the end through and retrieve it while you do the repair?
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
