Sump, Any good swear words?
Threads: 26
Thanks Received: 32 in 29 posts
Thanks Given: 9
10
So, a month after replacing the sump, I hit another poxy rock, denting the new sump.
No oil light, dent seems slight, no worry & I drive back.
Now at idle the oil light is on.
Worst case scenario, the oil pickup was blocked enough to damage the bearings on the way back,
but not blocked enough to trigger the oil light.
Wish me luck tomorrow when I take it apart.
227,00 miles, (Resurrected at 186,000)
Threads: 67
Thanks Given: 238
50
Good luck with it
Serieal Berlingo owner
Threads: 8
Thanks Given: 305
36
Lots of swear words but I had better not type them
Hope it works out ok.
If this is a regular problem for you, a strong sump guard could be worth the effort.
Threads: 26
Thanks Given: 9
10
25-05-2025, 05:12 AM
(This post was last modified: 25-05-2025, 05:13 AM by smutts.)
I think the pattern part sump I fitted last month was of much softer steel, a one hit wonder.
The previous one was a genuine Ford TDCi one, (half the price of PSA), & took about five good hits.
But it might just be bad luck, that the pan's first dent, is bulls eye to the mouth of the pickup pipe.
Threads: 26
Thanks Given: 9
10
It's apart, & no forbidden glitter in the bottom of the sump & the big ends haven't blued, the pickup pipe hasn't cracked.
So being the eternal optimist, I'll beat the pan straight, solder any cracks after the beating, dirko it all up (other sealants are available) and after the tedious wait for the sealant to cure, pour the oil back in & hopefully......................
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
Whats happened to the undertray?
Mines is badly scored so Im really glad I can put up with the wretched thing...
Threads: 26
Thanks Given: 9
10
Never had one, I assume lost in the 15 years of previous owners.
Was it actually a proper steel tray for the Escapade?
I never bothered getting another as I assumed it was the usual overpriced plastic gash.
but.........................if it was a proper steel jobby?
Threads: 26
Thanks Given: 9
10
29-05-2025, 10:37 AM
(This post was last modified: 29-05-2025, 10:42 AM by smutts.)
Oh, and I dodged the bullet, no funny noises, no oil light, power seems the same.
So celebratory beverage of choice.
So with replacement sump pans,
genuine might save, or at least delay grief,
as though mine fitted perfectly,
I think the metal is thinner & or softer,
so more susceptible to damage.
Threads: 67
Thanks Given: 238
50
Well done !
Threads: 81
Thanks Given: 165
20
The plastic one is tough and heavy-would go along way to prevent a repeat of all this.
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
