P0691 P0693 cooling fan circuit problem
Hi all,
Work van has come up with the warning triangle and after code reading I'm getting p0691 p0693 and p0493
All related to the cooling fan, I've currently got a tested fan on the floor infront of the van with the wiring accessible I've tested that I've got 12v to the relay but only 10 at the output? Not sure if that's normal, seems like power is there and it's earthed
Any ideas where to check next please? I've checked the large fuse under the engine fuse box and that's fine
Id check the fan with an independent 12v supply to completely eliminate the unit.
10v is only half the story -the relay might not be able to cope with the
current
Try a swapout or bypass it somehow maybe?
(17-06-2025, 10:02 AM)Jbaddeley Wrote:  Hi all,
Just a quick question what device did you use to get these fault codes as generic code readers are not really any use on PSA group vehicles and can lead you in completely the wrong direction?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
